I over tighten my oil drainage bolt
Old Apr 3, 2020 | 09:18 AM
willieiqaluq@hotmail.com's Avatar
Default I over tighten my oil drainage bolt
Where can I get a new oil tank for atv TRX 500 Honda, I over tighten my oil drainage bolt and its just leaking I added bigger bolt size 19 and it’s more dripping oil. Any suggestions what can fix it or where can I get a new oil tank?
This is the model.
Old Apr 3, 2020 | 09:35 AM
You might try eBay. Can't think of other sources where you might find one. Have you talked to the service department where you bought it?
Old Apr 3, 2020 | 10:48 AM
This is the model.
Old Apr 3, 2020 | 01:58 PM
RedRocket204's Avatar
You now understand the importance of using a torque wrench, and a good quality one at that. Many believe torque wrenches are to make sure bolts are tightened enough. When in reality, torque wrenches are far more important to make sure you do not over-tighten bolts into aluminum blocks and parts. It is so easy to over-tighten a steel bolt into aluminum and strip the aluminum threads, thus rendering the bolt useless. Same goes for over-tightening lug nuts on wheels and stretching the steel lugs.
Contact your local dealer and ask if there is something that can be done to fix your current issue. They may be able to properly tap the hole and provide a larger oil pan bolt. I know that is probably what you attempted to do, but sounds like it may not have been done right. I could be wrong, but don't think a heli-coil would work for that large of a hole which is oil pressurized. But like said, I could be wrong about that.
Old Apr 3, 2020 | 02:12 PM
scootergptx's Avatar
Supersock
Hired Gun!
Almost looks like the washer broke and part is stuck on reservoir. May just need to get that off (and a new washer) and be good.
Old Apr 4, 2020 | 01:40 PM
Huginn's Avatar
They make drain bold thread repair kits, but if you don't have any experience in installing these then you can make your problem worse. I was a professional Honda mechanic for over 20 years and by far the best thread repair kit is this one by Time Fasteners. But you can still screw it up even with the best parts.
https://www.timesert.com/html/drainplug.html
JustPlainBecky
Mar 6, 2008 11:24 AM
Viper65
May 5, 2006 10:26 PM
400exdude03
Jun 25, 2004 11:49 PM
DK1977
May 23, 2004 12:40 PM
800
Oct 6, 2002 04:07 PM
