2007 polaris sportsman 500
Old Feb 21, 2024 | 10:45 AM
Ethan Hill's Avatar
Default 2007 polaris sportsman 500
Hi I am new here I have a 2007 Polaris sportsman 500 EFI H.O It starts then dies in 3 seconds and when you give it throttle it just Boggs down and dies and backfired and sometimes when you try starting it for a while white smoke will come out of the throttle body, and when you let it idle it does the same thing and I already tried adjusting the cable tension and checked the gap and the thumb throttle box.
New Quantum Fuel System injector, Fuel Pump and Fuel pressure regulator basically the whole fuel pump replaced K&N Fuel filter K&N air filter, K&N oil filter, oil change done 20 miles ago New fuel lines and It does the same think when the air box and all of that stuff is off This is the second injector I have bought and like the 20th spark plug and the seconds fuel pressure regulator to, I honestly don't know whats wrong with it, it could just be something small or something big idk.
Please respond I have wasted a lot of money on this bike and I need all the help I can get i'm gonna try getting a new TPS but idk if that is going to fix it.
Old Jul 12, 2024 | 11:20 PM
Sportsman102's Avatar
Thumbs up hoping you figured this out
hi there i am hoping you figured this out...i am having the same issue by the sounds of it on my 2007 sportsman 500 EFI
please reply if you figured this out
Ethan Hill
Apr 19, 2025 06:15 PM
scubasteve3178
Apr 5, 2020 08:53 PM
Rescuedog9
Aug 6, 2010 02:55 PM
theBIRD
Feb 19, 2008 04:34 PM
edmo500
May 1, 2007 09:44 PM
