Kawasaki Side by Sides Talk about the rugged Kawasaki Sport and Utility
Mule 3010 problem
Old Jun 1, 2008 | 11:00 PM
EJW's Avatar
EJW
Default Mule 3010 problem
I have had a no start condition posted for a bit, now I have some new information to add to it... Discovered the no start condition to be a plugged air filter. The reason the air filter was plugged is because the crankcase ventilation system was drawing oil/fuel (due to misfire) into the intake. After removing the air filter the Mule ran, but still was drawing the oil/fuel mix. I changed the oil+filter and filled to proper level. Has ran without difficulty for approximately 1 hour. It is once again drawing the oil up into the intake. Why??? Thank you in advance for your assistance.
EJW
Old Aug 2, 2008 | 04:44 PM
easttnatvrider's Avatar
Default Mule 3010 problem"></title><script src=
I really wished you got an answer to this because I am having a similar problem. Mine will start and run but as soon as I get into the trottle it is bogging down. I also had oil in the air filter and am not sure why.
Old Aug 17, 2008 | 09:49 PM
shorse's Avatar
we had this EXACT problem...
we got a new air filter and it's ran fine since...
Old Oct 7, 2008 | 10:22 PM
shorse's Avatar
problem is back... no one knows why?
Old Oct 17, 2008 | 12:07 AM
Impact's Avatar
sounds like a cracked piston or something internal.....compression goes into crankcase and out of breather.
I saw something similar on a raptor.
Old Oct 27, 2008 | 11:07 PM
shorse's Avatar
only does it when it rains...
that help any?
Old Nov 8, 2008 | 10:07 AM
rjestes3's Avatar
Is it possible that you need a filter with less restrictive flow? I'm not too familiar with the Mule filter system, but a clogged filter or one with restricted air flow can cause increased suction on a rebreather line.
Jim
Old Nov 8, 2008 | 05:37 PM
shorse's Avatar
i go to the kawasaki dealer for a replacement filter, do they make ones less restrictive?
Old Nov 8, 2008 | 08:57 PM
rjestes3's Avatar
Check to see if a K&N makes a compatible air filter. K&N claims their filters increase air flow and increase horse power.
I think the 3010 Mule has an air filter restriction guage located just behind the filter housing. Check it often to see if it pops; if so, it would indicate restricted flow.
Clean unrestricted flow may not be the solution to sucking oil, but it's critical to a properly functioning engine.
Good luck!
Jim
Old Nov 9, 2008 | 03:10 AM
shorse's Avatar
the yellow button thing with a gauge on it by the air filter, what is that, when do i push it?
