Kawasaki Side by Sides Talk about the rugged Kawasaki Sport and Utility
Mule will not go into gear
Old Aug 31, 2008 | 10:39 PM
zitaron's Avatar
Default Mule will not go into gear
Can someone help? I've got a Mule to fix and never worked on one before ---it will not go into forward or reverse .... except if I stop the drive pulley spinning with my boot on the pulley, and then it engages fine.
Gearbox is ok ... what is likely to be causing this?
Old Aug 31, 2008 | 10:47 PM
teamhex's Avatar
Just a thought, why not look at it like this. If you have to use your boot to engage it, look at what ever should be engaging it.
Old Aug 31, 2008 | 10:58 PM
zitaron's Avatar
Thanks .. I was kinda thinking that way.. but I don't know enough about how they work to decide if there is a spring, or wear , or clutch problem, or what? All I know is -- when I stop the pulley/drive from spinning (by applying pressure to it) then the gears can be smoothly engaged
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
