What to use for grip glue?
Old Jun 1, 2003 | 01:08 AM
Andy~G's Avatar
Default What to use for grip glue?
Hey Guys
Im going to replace my bent handelbars tomorrow and need a little advice on what to use to hold my new grips on. When i bought the grips, the dealer didnt have any real grip glue but he said i could just spray the inside of the grips with spray paint before i put them on.
Anybody ever try that?
I would just use silicon RTV but I hope to get a little ridding in tomorrow so I would like something that drys fast.
Any suggestion?
Thanks
Andy
Old Jun 1, 2003 | 01:10 AM
KevinM's Avatar
I've always had good luck with 3M weatherstrip adhesive.
Old Jun 1, 2003 | 01:18 AM
Andy~G's Avatar
Thats a good idea Kevin!! Plus I could get that Home Depot early in the morning.
Thanks
Andy
Old Jun 1, 2003 | 03:09 AM
ballisticxrchris's Avatar
paint or super glue is ok. I prefer to wire my grips.
Old Jun 1, 2003 | 04:21 AM
MRMUCKY's Avatar
The fast cure version of JB weld works exellent, it cures in an hour, and those grips will not slip.
Old Jun 1, 2003 | 08:10 AM
Ryanstones's Avatar
It won't help you this morning, but i just learned this trick. wrap the bar end 2-3 times in regular masking tape, fill the grip with gas for 60 seconds or so, pour out gas and install grip. Takes a couple hours to set, but hasn't slipped yet. We'll see howthis works when it's wet out.
Old Jun 1, 2003 | 09:16 AM
predator530's Avatar
renthal grip glue but it is the same thing as 3m weatherstrip glue
Old Jun 1, 2003 | 11:01 AM
SpydrFreak's Avatar
Sounds silly, but I use my wifes hair spray. Dries like cement!
Old Jun 1, 2003 | 11:13 AM
Hardwood's Avatar
If you are putting on non heated grips I use 5min. epoxy and if you have heated grips you have to use the slow set epoxy or when the grips get hot the glue will not hold. I found the slow set at Ace hardware.
Old Jun 1, 2003 | 12:00 PM
Andy~G's Avatar
Thanks guys for all the good replys. I think Im going to try spray paint sinse I have some in the garage. If that doesnt work, I'll probley go with the weather strip stuff.
Thanks Again
Andy
