'02 650 Prairie KBEC Problem
anyone had this problem, or got a suggestion for a fix... I was doing some mods ( relocating my battery )...after reconnecting the battery cable & restarting the quad, ( it was in 4 X 4 mode ), I went to switch it into 2 X 4 mode, & the display started blinking back & forth between the 2 X 4, & 4 X 4 ... finally it switched into 2 X 4 mode... when I went to switch it back into 4 X 4 mode, it wouldn't go in... ( I did alot of winter riding last winter, & got caught in a few ice storms ) ( MAJOR SALT PROBLEM ) ( so I'm in the process of pulling conections, spraying them with contact cleaner, & sealing them with Dielectric grease )... I went through all of the conections from the switch to the actuator on the front diff... when I couldn't find anything wrong ( I was just about to send it to the shop ), I thought I'd look at the fuses...The 10 amp KBEC fuse was blown... I replaced it, & I got the 4 X 4 working, but the actuator on the belt for the KBEC system keeps cycling after I shut the key off ( I let it do it for over 5 minutes ) I was afraid it would do it until the fuse blew, or the battery went dead... I haven't gone through all the connections on the KBEC system yet, but haven't found any of the connections that I've pulled apart to be highly corroded yet... My belt is pretty worn & due for replacement, but I didn't have the cover off around the time of the problem developing... any suggestions would be greatly appriciated... Thanks, WAM
