How to Jet the 700?
Old Jun 18, 2003 | 12:51 PM
green700's Avatar
Default How to Jet the 700?
This is a formal request for instructions on changing the main jets. (I assume there are 2 carbs) I've jetted a mikuni on a blaster so I have a little bit of experience, but I'd feel better with some instructions. If there is a good link that will work too.
Old Jun 18, 2003 | 11:15 PM
98cobra's Avatar
I also would like some info on how to jet a carb on a 700 but I have no exp. doing it so a link to explain the whole thing woud be great or a brief explanation would do also. Thanks
Old Jun 18, 2003 | 11:18 PM
2003650's Avatar
I really don't know how to jet a v700 but if it's anything like my p650 it's not hard. Just get a brand new #2 phillips screw driver... your gonna need it! You might wanna check nyroc's website he might have some info there to help ya.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 20, 2003 | 12:48 PM
green700's Avatar
I havent changed the main jets yet but this is what I've heard.
1. Remove plastic over airbox
2. Remove snorkel to clutch & another piece of plastic in the way
3. From the clutch side of the ATV you will see 2 carbs with 4 screws each
4. Remove the 8 screws, be carefull because they strip easy
5. You now have access to replace the mains.
I havent jetted yet but I suppose draining the carbs first would keep you from bathing in gas. Also I think steps 1 and 2 are required for cleaning the rear spark plug if you do that. I did buy some smaller jets since I'm at 4600ft but I'm gonna play with the airbox a little instead of using smalller jets for now. I suppose when the K&N comes out I may actually have to get bigger jets.
