KFX400 engine problem?
Old Jun 22, 2003 | 03:39 PM
BogSpores's Avatar
Default KFX400 engine problem?
I didn't see a limiter override button..........but I'll ask the dealer if such a thing is available......
Old Jun 22, 2003 | 08:42 PM
Chris142's Avatar
Check the vent hose under the ignition switch holder thingy. The hose comes off of the cap and pushes into the plastic cover thing. Under the plastic is another hose that is supposed to go down the steering stem. See if it's kinked under here.
Most guys are removing the lower vent hose altogether.
My friends wife's Z-400 quits running altogether and nobody not even 2 dealers can figure out why (bike is 8 mths old, only 10 hours on it or so). I think the CDI box is bad but it's a real expensive guess.
It wont quit for the dealer it only quits on us 30 miles from home.
The carbs on there bikes are very tempermental to elevation changes. I'm at 3100 ft and the bikes run ok.....get over 4000 ft they foul plugs and just run terrible.
Old Jun 23, 2003 | 02:43 AM
BogSpores's Avatar
Thanks for the info Chris142.....I'll check out the hose under the "dash".....
Yesterday, I noticed it's still doing the same thing.....with a FULL tank of gas.....
I approached a medium steep, sandy hill.......with the tranny in 2nd gear......at really low speed, then "romped" on the throttle.....it revved, then sputtered, started missing.....revved some more, sputtered, but eventually made it over the hill.......
Sure, I could have downshifted, but I figured with the torque of this engine, it should "lug" over this hill at least without "missing, sputtering" and appearing to have engine problems?......
hmmmm.......I'm still stumped.......and I'm afraid I won't be able to demonstrate this to the dealer, since it only happens when the engine is "loaded" (going up a hill, at slower speeds, in 2nd or 3rd gear)......
Old Jun 23, 2003 | 03:33 PM
FsT4WrD's Avatar
Are you sure your not hitting the rev limiter while going up the hill ? If it is sand and you still have the stock tires your probably spinning while going up the hill and if your in 2nd it will hit the rev limiter . Try to approuch the hill in 2nd then up shift at the base of the hill and you should burn up it pretty good .
Old Jun 23, 2003 | 04:09 PM
  #15
BogSpores's Avatar
could be, but I don't really think so.......for example, the other day, while out riding (with my 4yr old between me and handlebars), I approaced a medium-easy hill.....I was in 2nd gear, cruising toward it, at no more than 15mph......I'd guess my engine speed at 2500-3000rpm......as I neared the base of the hill, I started to increase the throttle.......once I got on the hill, the engine had sped up, but only to what I'd estimate at 4500-5000rpm (probably less)......in fact, if I'd have downshifted to 1st, it would have revved much higher, and the "engine miss" would have gone away......
It seems to only happen when I "load" the engine at a low speed/rpm...........So for now, the answer is simple....."Don't load the engine at such a low speed/rpm..." heh heh........
Honestly, I haven't revved the engine high enough yet, to even know what the forward rev limiter sounds like.......although, I've discovered the reverse limiter, and know it's sound all to well.....
Old Jun 23, 2003 | 04:58 PM
  #16
FsT4WrD's Avatar
I think you should take it out and beat on it for a day to blow out the bugs
Old Jun 23, 2003 | 05:11 PM
  #17
BogSpores's Avatar
heh heh......yeah, you're probably right!.....
I'm going to mention it to the dealer when I take it in for the 1st service next Monday......although, unless they ride it up the same type hills, under the same conditions, they won't be able to see the problem......
Old Jun 23, 2003 | 10:30 PM
  #18
pads's Avatar
What does your spark plug look like? That will be the indication if it is running way too rich, near to fouling.
Old Jun 24, 2003 | 02:32 AM
  #19
BogSpores's Avatar
I thought about the plug......haven't checked it yet, due to it's limited accessability.......I'm new to this engine, and was shocked to discover the plug seems "buried" between those twin cams!.....
How hard is it to check/change?......
Old Jun 24, 2003 | 09:31 PM
  #20
Chris142's Avatar
Gettin the plug out isn't bad. Just use yer quality [img]i/expressions/face-icon-small-happy.gif[/img] sparkplug socket that came with the bike.
