P650 is dead
Old Jul 14, 2003 | 10:45 PM
beardog's Avatar
Default P650 is dead
My 650 is completely dead. When I turn the key on it does absolutely nothing. No lights and no system checks. I tried to start it with the pull start and it ran untill the carburators ran out of gas and then it died. While it was running the speedometer was randomly showing numbers. The battery is charged. Any thoughts or ideas ???
Old Jul 15, 2003 | 08:11 AM
newbeatle's Avatar
Check your ,main fuse, it is under a pink cover on what looks like a coil wire conection ( not a coil wire conection though )...WAM
Old Jul 15, 2003 | 08:32 AM
beardog's Avatar
I Checked out three fuses under the seat and they were ok, but I will look for the main fuse. This is probably the problem. I was in the process of hooking up an attachment to the rear power supply. Thanks for the reply.
Old Jul 15, 2003 | 08:56 AM
newbeatle's Avatar
The main fuse is 4"-6" away from the other fuse block, also under the seat...I did the same thing... I'm sure thats your problem, good luck...WAM
Old Jul 15, 2003 | 09:15 AM
jlpier01's Avatar
The main fuse can get you! My rear accessroy plug melted on the muffler and shorted me out in the mountains of WV. Be sure to secure that plug before you take off.
Old Jul 15, 2003 | 11:33 PM
beardog's Avatar
I checked the main fuse and it was blown. I guess when I was messing around with the rear power supply I must have blown it. Thanks for the advice.
pgamboa
Dec 24, 2023 11:52 AM
slowgsxr97
Mar 18, 2022 03:40 AM
DM2015
Sep 7, 2015 10:36 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
