P650 head gasket?
Is there a thinner head gasket that can be purchased or cross referenced? Are there any dangers of running without a head gasket? It would have some form of thin gasket like form a gasket? What would the compression be if i didnt run a head gasket? Is anyone running without a head gasket? Is it worth doing or i wont notice much power difference?
thanks
thanks
you can't run without a head gasket unless you want to ruin your motor. that gasket maker stuff you are talking about will not hold up as a head gasket. if you already have the heads off just take em to the machine shop and have em shave off a little bit. if they shave off too much then you will have to run a lot higher octane gas, like 110 racing fuel. i doubt you will notice that much power increase if you do this mod.
jrooker6
Apr 23, 2016 07:36 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
