lakota vs. warrior
as an all around atv which would be the better buy. there is a huge price diff. so i would have to buy the warrior used. im lookin at a lakota at the local dealer. i was thinkin on buyin it if i can sell my old quad (trailblazer) if it can even be called a quad. but any way around here there is mostly mild riverside trails we alot of fields to ride in and some home made mx courses. wht do u suggest.
thanks
Dr89
thanks
Dr89
both of those quads are heavy for mx but I would give the nod to the warrior for mx. The warrior will run at a quicker clip than the lakota. If you don't want to use a clutch go with the lakota. Using a clutch isn't hard though so I would go with the warrior. It is also like 40 pounds lighter.
well the lakota and warrior are about even in trails and fields,also there both rock solid quads these two atv's can take a beating and still be in good shape.For mx the warrior would be better with the manual clutch and the warrior tops out about 5-6mph faster,but if the lakota has a real good deal,i would take it,but if the price is'nt an issue take the warrior.
