Nabor module review.......
Old Aug 12, 2003 | 12:52 PM
bbertram's Avatar
Default Nabor module review.......
Cool cool cool.....go newbeatle!!!!
Old Aug 12, 2003 | 01:38 PM
SHOTGUN's Avatar
newbeatle
WAM [img]i/expressions/face-icon-small-happy.gif[/img]
red650, what about yours, how's it working.
Old Aug 12, 2003 | 02:12 PM
reds650's Avatar
the same as the nabour one
have had no problems with any of them
Old Aug 12, 2003 | 03:24 PM
Fireman650's Avatar
i do notice a boost in the mid range, ex: going around 40km and hitting the throttle i notice a nice boost over stock. It appears to do the same at different speeds as well, 50km. I am pleased with the improvements, i wonder if this module will also work in conjunction with the DG top end if and when that arrives.
Old Aug 12, 2003 | 04:24 PM
  #15
newbeatle's Avatar
I've done up an excel spread sheet with the tests I'll be running this weekend... they will include 2WD, 4WD, & 4WD ( 28" tires ) in the following tests, with no module, with the D.G. Hole Shot Module, with the Naber Module... 0 - 20mph, timing
20 - 40 mph, timing
1 / 2 mile , speed
100' timing / speed
300' timing / speed
20 - 40 mph, timing
I'm having some trouble with my e-mail / internet right now... this new virus ??? ....I intend to run these tests on Saturday... we will run them rain or shine... overall impressions will be included... my 1st impression of the Naber unit, is a question as to how water proof / resistant it is in the form I recieved... I'll be putting connectors, similar to what NYROC decribed to facilitate changing the modules... I'll be commenting on rev limit feel, & power band feel... I'll be documenting these tests with a tach, If it arrives in time to use it during testing...if there are any other tests that any of you feel I've overlooked, please feel free to comment...WAM
Visual impressions of the DG module... the module is about .75" X .75" X .5" & is epoxy filled... appearing fully viberation & water resistant, has 3 wires & comes with pinch conectors...
Visual impressions of the Naber module... the module is about 2.5" X 1.5" X .75", appears to be 2 parts, plastic welded together, there are 2 small phillips screws that appear to also hold the halves together... black silicone appears to seal the hole that the 3 wires come out of... Naber reccomends soldering the connections & using heat shrink tubing... both modules hook up to the same wires off of your CDI
If my tach is here in time ( supposed to be ) I'll record RPM limits as well...
Old Aug 12, 2003 | 04:32 PM
  #16
sledgehammer650's Avatar
will this module work with the holeshot that i already have??? Or should i wait for thedg top end module?
Old Aug 12, 2003 | 05:54 PM
  #17
bbertram's Avatar
I hope its water proof, if you don't mind punishing your module, after all the tests are complete do a water proof test. I'm sure if the module is damaged in any way during that test Nabor would replace it. I don't want you to damage your CDI or anything though.
Old Aug 12, 2003 | 07:18 PM
  #18
KISSSOFDEATH's Avatar
2 piece module? welded together? good luck with it.
Old Aug 12, 2003 | 09:03 PM
  #19
bbertram's Avatar
I think I will be wrapping this module in electrical tape or find some heat shrink tape and make it water tight. I emailed Ted asking if the module is water proof or not.
Old Aug 12, 2003 | 11:20 PM
  #20
nyroc's Avatar
Use goop. Messy, but tough.
