what oil is recommended for the 700
Sorry for the lame question, but... What oil does everyone use for their 700? I'm not too knowledgable when it comes to this kind of crap, that's why I'm in the IT business =] I figure it'd be alot cheaper to do it myself than pay the 40-50 bucks that the dealer is wanting. I looked in the owners manual and didn't really see if it said it needs full synthetic or not, or is it a synthetic mixture? How often do you change it? I think I read 30hrs or so somewhere, that seems like a bit of time for a change...?
I AM RUNNING THE KLOTZ MX4 15W-50 IT'S A FULL SYNTHETIC. IT'S THE BEST OIL I'VE EVER RUN IN MY PRAIRIE. I SELLS FOR ABOUT $8.50 A QUART, BUT I THINK IT IS WORTH IT... I WOULD ALSO RECOMMED RUNNING EITHER ENGINE ICE OR WATER WETTER AS A COOLANT....HOPE THIS HELPS...
I used Valvoline ATV Blend 10-40. Go it at the local auto parts dealer, I think it was 3-4 dollars/qt.
It met all of the specs in the manual for the KFX700. The oil change is pretty easy, just make sure you grab the washer off the drain plug to stick back on there.
