Prairie swingarm bearings
Old Nov 9, 2003 | 08:32 PM
FastEd's Avatar
Default Prairie swingarm bearings
Guys,
The swing arm doen not appear to have any play in it. I jacked up the machine, removed the rear shock and and tires and tried to move the swingarm in many directions. It only moved in it's normal up and down direction with no side to side play. It did not make any noise when I did this. If i jump up and down on the foot pegs it will make the noise almost every time. Sounds like a loud popping /snapping noise. I really do not want to tear down the entire rear end to find that nothing is wrong. I will do so though if I can not find the source of the noise soon. I do not want to take a chance on further dammage. Thoughts?
ED
Old Nov 9, 2003 | 09:16 PM
roscoe69's Avatar
FAST ED
yep your bearings are gone, when shifting your weight back and forth it pops or snaps, its a sure sign they are screwed
Old Nov 10, 2003 | 06:20 AM
therock's Avatar
Hmm? Yes you could freeze them and it may help. They should not be a press fit. To really diagnose the bearings I would remove the tries and disconnect the shock. Then move the arm up and down or side to side feeling for a bind or noise.
If and when the arm is pulled off, remove the drive shaft and check the u-joints for stiffness or if the caps are turning in the bores. Take care not to loose the spring in the diff input shaft.
Old Nov 11, 2003 | 02:41 PM
FastEd's Avatar
Guys,
You were right on the money. My swingarm bearings on both sides were completely TOAST. Root cause analysis=the rubber plug in the swingarm underneth the rear skidplate was missing!![img]i/expressions/face-icon-small-disgusted.gif[/img] Lucliky, the 424 in the rear diff had enough emulsifiers in it to save the bearings in the rear end. I have no idea how the plug could be missing. I have never removed the skidplate that is covering the plug so I assume that it must have been missing since new. I have drilled and tapped all of the plug holes now and have threaded plugs in place of the rubber ones. I totally cleaned out/rinsed the entire swingarm and am in the process of installing the replacement roller bearings (Thanks The Rock NAPA PN is same as Timken 30203) A few more hours and I will be on my way to the trails!!
ED
Old Nov 11, 2003 | 03:41 PM
  #15
MURPH1's Avatar
I just did mine last wekend. I had the same problem that there was no play in the swingarm
but when i steped from floorboard to floorboard it would make a poping noise. The rises where
a pain in the a$$ to get out but the new ones when in without a problem. My swingarm boot
was torn and it was like that all summer, so the water and mud got in and rusted the bearings.
I check the boot in may and it was fine. I put almost 1200 miles on with the boot torn. I dont think
it damaged anything else. The bearings,rises and the boot cost 100 cnd or 65 usd.
Old Nov 12, 2003 | 06:23 AM
  #16
therock's Avatar
The boot getting torn is one reason why I put The Ricochet skid plate on. It extends a tad over 2 inches rearward more than the OE foil.
Old Nov 12, 2003 | 08:25 AM
  #17
trx450's Avatar
Try: http://www.bdi-usa.com/ for bearings. Never done them. These people might have the brngs., or could get them.
ReconBayou
Oct 16, 2019 02:24 AM
exmotocrosser
Sep 13, 2019 06:12 AM
hueby
Nov 6, 2015 11:34 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
jbrewster94
Sep 23, 2015 04:16 PM
