k&n filter and jetting question
Old Sep 13, 2003 | 07:44 PM
ansible's Avatar
Default k&n filter and jetting question
if i order the k&n filter do i need to adjust my jetting at all or will it be fine? also im at a higher elevation now, rapid city south dakota, so im not sure what the elevation is here, just probably a lot higher than usual. if so, what kind should i get and do i need any special tools to install them? would it be hard? thanks!
Old Sep 14, 2003 | 12:21 AM
ansible's Avatar
no one knows?
Old Sep 14, 2003 | 12:26 AM
Albee39's Avatar
Looks like your elevation is 3247 FT. according to my road atlas. I am at just over 6000 ft here in Cheyenne. With just a filter change I dont believe you will need to rejet. If you do airbox mods and maybe an aftermarket exhaust you will probably want to do something with the jetting. But just a filter, I dont think so. You are running a little rich being at your altitude now, so you may just bring it down to a good level. Good Luck.
Old Sep 14, 2003 | 12:39 AM
ansible's Avatar
Thanks for the info!
Old Sep 14, 2003 | 01:03 AM
ZX2's Avatar
ZX2
Are you getting rid of your air box? I did. I found that with just the K&N filter I used a stock #155 jet at my alt. It was a little rich. I do sugest getting the DYNO JET KIT it realy makes a difference. With the dyno jet kit and an FMF power core 4 pipe I'm useing a #146 jet. Keep in mind that the Dyno jet kit has a diffenent #'ing system than the stock carb so they don't line up. For a stock jet I would probaly use a #160. No special tools are needed but I do sugest a SNAP-ON phillips screw dirver or you will strip all of your screws on the carb. I Also would dip the screw driver in a grinding compund to get a better grip. good luck.
Cole Hadden
Jun 15, 2025 09:05 AM
house1
Aug 9, 2015 10:49 PM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
cSchwartz
Jul 9, 2015 02:43 PM
