Help with pink spring installation
How and the heck do I get the center nut off so I can remove the original spring and install the pink spring? I put 265 fat pounds on it and it wouldn't budge. Also what do I torque everything back to?
The center bolt is reverse threaded. You'll have to put some big force on it clockwise now that you've overtightened it.
The torque spec is 69 ft lbs for the center bolt and 113 INCH pounds for the face plate.
I used a 1/2 - 3/4 inch wood rod about 1 - 1.5 feet long. I ran it through the clutch and wedged it agains the frame. This stopped the clutch from spinning and made it possible to get the bolt out
i think kawasaki overtihgtens them from the factory, i used an electric snap on impact gun and it came off no problem. let me now if your going to buy a pipe for your bike, i can get you a DMC ALIEN dual set up and the correct spring spring for 470.00
