Tires on my '00 Prarie
Does any one know what size tires I can get without dramaticly changing the power? Also what kind of tires would you recomend me getting? There's one more question I have. Does any one know what kind of performance mods I can make to give me more low and top end power?
[This message has been edited by PrarieTy (edited 01-16-2000).]
300 or 400 Prairie? The answer is critical for responding to your hop-up question.
With an automatic transmission, continuously changing drive ratios respondig to load, you should have considerable latitude in choosing tires. A friend uses Mudrunners on his Bayou fleet (300 & 400) with great satisfaction.
Tree Farmer
Tree Farmer
If you go with bigger tire's I would suggest a K@N air filter with a jet kit to increase overall power. Hopefully it will be enough to counter the extra weight of the bigger tire's. I have the 99 400 and it has plenty of power with stock tires. My friends 400 felt a little strained with 27" vamps. Since you have the 300 prarie- good luck.
[This message has been edited by DaveC (edited 01-27-2000).]
09-30-2015 02:37 AM
