plow
Old Oct 3, 2003 | 09:29 PM
sicnj's Avatar
Default plow
what is the best kind of plow to get ? one you use with a winch or electric lift
Old Oct 3, 2003 | 10:16 PM
ElectricShift's Avatar
Default plow
electric lifts are better, less wear and tear.....but you can also get a shorter rope or cable and use that on your winch to save the longer cable.
Old Oct 3, 2003 | 10:34 PM
sicnj's Avatar
Default plow
it really wears down your winch that bad?
Old Oct 3, 2003 | 11:05 PM
Default plow
not really bad, its just not as good for it as using a shorter rope or cable.
Old Oct 3, 2003 | 11:16 PM
sicnj's Avatar
Default plow
thanks grizz can you look at this auction and tell me if its a good deal. plow
also would you go with this plow or a smaller one? what is easier to use?
Old Oct 3, 2003 | 11:19 PM
DustinMinnesota's Avatar
Default plow
I have a Moose Plow and Mounting Kit on my 650 and the thing is great. Heavy Blade and heavy tubes for ruged construction not like those other cheap plows that bend.
I hear the Warn blade is heavily constructed too.
Old Oct 3, 2003 | 11:23 PM
sicnj's Avatar
Default plow
how much did you get that for and where?
Old Oct 3, 2003 | 11:37 PM
Default plow
I bought mine at a local dealer and the cost was around 325 I believe. That was everything minus the winch. The winch was around 3 something but I already had that when I bought the quad.
Just did a quick search for it and found hundreds of places selling them shop around you will need just for the plow
A lifting mechanism (if you do no have a winch)
Plow
Push Tube
Mounting Kit
Look here for your part numbers
http://www.mooseutilities.com/frames.asp
Old Oct 4, 2003 | 09:18 AM
sicnj's Avatar
Default plow
can anybody tell me anything about the cycle country plow. Is it a good strong plow or is it going to bend on me.
shimanok2
Jan 29, 2016 07:37 PM
kampswas
Sep 23, 2015 05:05 AM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
