Prairie 700 vs Predator 500
Old Oct 13, 2003 | 11:03 AM
bullydog's Avatar
Default Prairie 700 vs Predator 500
Would the prairie be able to keep up with the predator in a drag race and if not what mods can be done to the prairie 700
Old Oct 13, 2003 | 04:49 PM
KISSSOFDEATH's Avatar
I would say you dont have a chance at any distance with a stock P700.
You would have to add both the Hole shot and unlimiter modules, rejet, change your air intake and filter, install and aftermarket pipe such as an HMF or do the muffler mod, and install an EPI Red or Dalton Black/White primary spring. You may or maynot want to install the EPI Black secondary spring. BY ALL MEANS run your STOCK Tire/wheel setup. That is the least amount of unsprung weight you can get.
If you do all this you might be able to keep up with at Predator in 300'.
If you do some engine mods then things may be different.
Old Oct 13, 2003 | 04:57 PM
STAKK's Avatar
I would put the Penland, Web, or Mickey Dunlap cam's in also along with everything else, then you will have a shot......
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
PrairieDog126
Sep 12, 2015 05:23 PM
Elkaholic
Sep 6, 2015 02:44 PM
