clean filter question
Old Nov 12, 2003 | 12:08 AM
400PrarieXLT's Avatar
Default clean filter question
Just cleaned my filter again tonight. I have allways heard not to use gas on it because it breaks down the foam. It was so oily this time, that I broke down and sprayed it with gas, oil came right out along with all the funk. I cleaned it, resprayed it with kawi spray filter oil and its good again.
Is there a better way? some kind of cleaners that really do the job? Nothing ive tried holds a candle to the way gas gets it clean. Thanks.
Old Nov 12, 2003 | 12:37 AM
pulverized's Avatar
I've always used gas on my foam filters, just make sure they are good and dry before re-oiling and installing. I've never had a problem as far as the foam breaking down faster, but I usually replace the foam with a K&N as soon as possible.
Old Nov 12, 2003 | 12:57 AM
Thanks. I just started using gasoline and if I notice it breaking down, I will buy a new filter. I ride in way too much dust for a K&N. Anybody know if there is a filter cover, like an outer filter you can use over a stock filter? Thanks again.
Old Nov 12, 2003 | 10:08 AM
MikeyBoyesq's Avatar
FYI: I always use dish soap to wash out my foam air filters and let them dry overnite before I add the oil to the filter. It works fine for me.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 12, 2003 | 10:31 AM
After a few washes and re-oils, the oil has built up so much that dish soap didnt cut it anymore. i guess it never really removed it in the first place. The gas cut it right off, no problem. Im going to the dealer to price a stock filter. That way, I can just swap them back and forth, and allways have a clean one waiting for me when i need it.
Old Nov 12, 2003 | 01:14 PM
trailburner's Avatar
if you are going to spend any money on a filter, order a twin air. They are great filters.
Your local dealer will also have cans of cleaner for the filter. The cleaner works really well. I think it's called PJK or something similar to that. It cleans well and then you just rinse it off and all the dirt and grime just washes away.
lightninboy
May 16, 2021 09:52 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
