Primary Spring Replacement
Old Nov 14, 2003 | 10:40 PM
Puttnutt24's Avatar
Default Primary Spring Replacement
Man, without Nyloc's website, a search on this is useless.
Do you have to remove the entire "Driven Pulley" to remove and replace the Primary spring in order to install a Pink primary spring on a V-Force? thx in advance, Putt
Old Nov 14, 2003 | 10:48 PM
Puttnutt24's Avatar
Sorry, I meant to type Nyroc's website, excuse me, Putt
Old Nov 14, 2003 | 10:55 PM
KevinM's Avatar
I happened to take some pictures the last time I changed mine just in case someone needed a little help:
Old Nov 14, 2003 | 11:27 PM
trailride's Avatar
kevin. at the bottom of your page on spring replacement you saib "be sure to lin up the holes" what are the holes you refer to?
Old Nov 14, 2003 | 11:51 PM
Puttnutt24's Avatar
Kevin, I can't thank you enough, I was way off, looking at the service manual, I thought the primary spring was under the rear (driven) pulley, not the front (Drive) pulley. Seems real simple, thx, Putt
Old Nov 15, 2003 | 01:40 PM
KevinM's Avatar
On the back of the cover, 2 of the holes have short sleeves sticking out about 1/4 inch. You can see them as soon as you turn the cover over. They must be lined up with the corresponding larger holes in the primary clutch.
Old Nov 15, 2003 | 02:35 PM
SHOTGUN's Avatar
trailride
Notice on the face plate there is an arrow. That arrow should be directly over an arrow that looks just like it on the spider.
Those are aglinement marks, for balance.
Old Nov 15, 2003 | 02:47 PM
Puttnutt24's Avatar
Hi Shotgun,
By drilling hole's evenly as you did on your clutch, what exactly does this do? Thx, Putt
Old Nov 15, 2003 | 06:31 PM
SHOTGUN's Avatar
Putt;
Rotateing weight robs HP, so any weight saving on anything that turns, will increase RPM's. For pulling my tires robbed so much power, that it killed my Rpm's, I couldn't find lighter fly weights so I started lightening my clutch and anything that turned to get the RPM's back up.
The bike will rev faster and get to speed quicker. We have done clutches from the holes like kevin has all the way to removing cooling fins on the back side of the clutch.
Go to Dalton's site and look at their overdrive clutch plate, they went one step farther than the holes and removed every other section, by doing this they allow the spider to move more, giving more top end.
Good luck with the spring!
Old Nov 15, 2003 | 08:00 PM
KevinM's Avatar
Works very similar to lightening the flywheel on your engine, lets the RPM's build quicker.
Very good tip Shotgun, I'd never thought of it until I saw yours.
toonces
Jul 28, 2015 01:58 PM
ghost civic
Jul 27, 2015 03:15 AM
Schneider
Jul 24, 2015 05:05 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
