harley msd ignition on vforce
Old Nov 23, 2003 | 02:24 PM
fullthrottlevforce700's Avatar
Default harley msd ignition on vforce
why couldnt someone use msd ignition from harley adapt it to vforce both use sensors to trigger fire anybody care to answer
Old Nov 23, 2003 | 02:26 PM
reds650's Avatar
does the harley ign run off the crank or cam?
will the rev limit go high enough
Old Nov 23, 2003 | 02:42 PM
harley msd ignition runs on crank i believe and has adjustable rev limiter
Old Nov 23, 2003 | 02:45 PM
rev limiter is only 9250 dont know if its high enough or not
Old Nov 23, 2003 | 02:51 PM
reds650's Avatar
can the firing be changed from 45deg to 90deg
9250 should be high enough
Old Nov 23, 2003 | 03:00 PM
dont know can be changed good ? how about use same trigger sensor from vforce and wire it to harley msd ignition then to coils to fire
Old Nov 23, 2003 | 03:10 PM
reds650's Avatar
the msd box uses two pickups v-force uses one
Old Nov 23, 2003 | 03:38 PM
reds650's Avatar
i think it runs off the cam[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Nov 23, 2003 | 07:33 PM
reds 650 u talkin vforce fires off cam
Old Nov 23, 2003 | 07:49 PM
reds650's Avatar
no the harley
