shift linkage adjustment
Old Dec 12, 2003 | 01:32 PM
jc82's Avatar
Default shift linkage adjustment
Thanks for the info. I will try to adjust the linkage soon as I get a chance
Old Dec 14, 2003 | 05:22 PM
sledgehammer650's Avatar
Shotgun i'am not sure about your directions. If your doing the final adj. how do you make the neutral light go out if you don't let the trans lever move. I thought that the trans. lever is what made the light go out. I took the rod off and now i'am at a point where i get the light off and its not working out so well. Help please.
Old Dec 15, 2003 | 10:14 AM
SHOTGUN's Avatar
sledgehammer
once you get the tranmission centered in neutral it just a matter of adjusting the rod, so the shifting lever is in the middle of neutral when it is setting in the notch for neutral..
If you get it adjusted right for one gear, it'll be right for all gears.
Old Dec 15, 2003 | 07:08 PM
Thanks shotgun i had took off the shift guide so it would be easier to move the rod i'll put it back on and take a look at it. I was just not sure about the neutral light going out while you turned the rod. I try to adj. it agian in the daylight to make sure of what iam doing is right. Thanks!
patrick.oc123
Sep 16, 2015 03:45 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
