Kawasaki Mojave 250 Cams
Does anyone know were I can get a nice used set of cams for a Mojave I have a friend who bought a used Mojave brought it home took off the top valve cover and the intake cam was wiped it runs and idles but it sure took alot of grunt out of it. I only need the intake but would buy the set any one have a set or know were a guy can buy a set cheap??? thanks also is it very hard to change the cam out as well???[img]i/expressions/face-icon-small-blush.gif[/img]
It's easy to replace the cam(s). I recomend that you buy a Clymer or Haynes manual to do it.
You also must replace the follower. My Mo needs a cam also and shopping around I got several different prices from several different shops. So shop around.
It's a common failure item in the Mo. It's caused by the tilt of the engine, the intake cam is hanging out in the wind while the exhaust is in an oil bath.
I have heard of having the cam hardened which should make it last longer. Another thing would be to run either Synthetic oil or a good dino oil that contains lots of Molydysulfide (Moly). The Moly will penetrate the metal and help prevent dry starts.
Torco oil has tons of Moly, Pennzoil is next then QS I believe. Valvoline has none!
BTW: The Moly may make the clutch louder when slipped but so far my clutch is ok, just louder which I can live with if it keeps the cams alive.
Go to Http://Bobistheoilguy.com and read up on oil. It's quite fascinating and good luck with your cam replacement.
A great place to get used Mojave parts or any other quad for that matter is quadpro
I have had amazing luck with them! Every part i got was as good as new and shp fast and GREAT prices, they have a web site that you may want to go to! www.quadpro.ca
check it out
check it out
Scooter's Shop
23
10-22-2015 07:04 PM
