v force belt deflection adjustment?
my belt has about 1 1/4 deflection. i have put a new primary spring in. so i can get that far. i need to know what shim to get, where to put it, and where to get it. will the dealer have it in stock, if it is the same as the prarie they should have plenty, right?
shake the little guide pins out of the middle (without losing them!), slide the pullies apart, REMOVE a shim to tighten belt.
As for the Dealer stocking it .... good luck! My dealer doesn't stock anything like that. They don't even stock the belt!!
The answer the phone saying "parts deptment." but they ain't fooling me... they should be saying "order department".
( Norris in Medina Ohio )
Steeldon
09-09-2015 09:38 AM
