Cold Starting V-Force
Anyone have any tips for starting the V-Force in the cold. Takes me forever even on 40-50 degree F days. I usually go full choke and blip the throttle while hitting the starter. My Raptor would start in the cold very easily compared to this quad.
Cold? you call that cold????[img]i/expressions/face-icon-small-wink.gif[/img]. I have started my V full choke no issues at -15 C. It sat outside for a week then fired her right up. I had to let it idle full choke for 2 or 3 min. I was more concerned that the battery would be dead . You may want to keep off the throttle. Try turning up the idle as you ease off the choke. Also, make sure your carbs are sync'd.
Are there any good dealers in the "Florence Y'All" area?? I am heading down your way in March for our anual engineering conference in Lexington. I always fly to Cinci then drive the last 70 miles. I am looking to do some "shopping" during the week. I hear there is a not bad dealer in Nicholasville.
You could try the fuel switch selector to PRI then switch it back once it is running. You shouldn't have to do this though as some have this issue and others do not. Talk do your dealer. If he doesn't give the answer you need then find another dealer to talk to. Mine fired up at 0 degrees F no issues after sitting outside for a week. Sounds like a fuel flow issue. The PRI will dump fuel into the carbs directly but you should not have to do it every time. Does the fuel pump run after the key is switched on??. Mine ran for 10 seconds once I turned on the key. THEN I hit the start and away it went.
Check around as this is not normal
we have a automatic compression release it opens the ex valve
starting compression is 47-81psi if it's on the low end it's not going to start good in the cold[img]i/expressions/face-icon-small-disgusted.gif[/img]
mine at -20c sounds like it has no compression and is very hard to start
buy some startin fluid.. do a 2 second squirt right on ur air filter and wham she starts up like a kitten on crack LOL.. i used it all the time on my bayou when the carb was completely CLOGGED but i finally said f-it and payed the 500 and got a new carb (plus full servis ect ect ect)
