supertrap
Old Jan 3, 2004 | 03:45 PM
ronshonda's Avatar
Default supertrap
any one have info how to take one apart the nuts where you screw in the discs are stripped
Old Jan 3, 2004 | 09:11 PM
Chris142's Avatar
Default supertrap
I had the same problem. Stupid stainless screws are too soft. I ended taking the core out and drilling the screws out then re-welded in new nuts. I replaced the stainless ones with more stainless that were covered with antisieze and after one ride they were frozen/stripped also.
Next time I'm gonna use regular screws loaded with antisieze.
Old Jan 3, 2004 | 09:37 PM
ronshonda's Avatar
Default supertrap
Chris142 how did you take the core out was woundering if you take the screw out of the side and tap everything out backwards
Old Jan 3, 2004 | 09:44 PM
Chris142's Avatar
Default supertrap
Ya basically. Mine is held together by the clamp that clamps the muffler to the pipe. Once the clamp is loose you can tap the inner guts and packing out.
I have seen other applications that used a rivit or screw to hold the core in the muffler. If you have this type you must remove/drill out the rivit or screw.
scottsdalebomb
Apr 25, 2004 06:55 PM
clover
Jul 29, 2003 12:04 PM
2000IAWarrior
Jul 22, 2003 11:41 PM
IronBear
Jan 20, 2003 07:45 PM
