700 v-force engine noise
Old Jan 6, 2004 | 06:13 PM
HUNDREDSPKBALLER's Avatar
Default 700 v-force engine noise
I have an 04' v-force and when i first start it in the morning it sounds like the engine is knocking or something. it does this until it gets good and warmed up. anybody know what i am talking about or how to fix it???
Old Jan 6, 2004 | 06:31 PM
vtwiner's Avatar
HUNDRED...
Yeah, I know what your talking about. What weight of oil are you running? I had the same problem when I was running 20W50. Try running a lighter weight oil during these cold months and see what happens.
Old Jan 6, 2004 | 07:08 PM
VFORCINATER's Avatar
I dont know if mine had a is simular problem but hear goes.
Yeha in the morning warm weather on not I think I had the same problem.
You need to listen closely to the moter! is it a knock like sound? Like it is missing or has a slight spudder.
Mine had a spudder to it along with the knock noise. It was this knock that I am talking about and was hearing. When I would 1st start it up it would run and then in a quick instant this quick knock/spudder/miss. Then it would run fine again and then anouther quick nock/spudder/miss again and this would go on until it was warmed up.
Turns out the carbs were off sinc buy just a little.
check it out
Old Jan 10, 2004 | 11:35 AM
chop's Avatar
how do you get the carbs in sync and how do you know if their not in sync?
greg74
Sep 10, 2019 03:03 PM
ronnierhino06
Nov 9, 2015 12:56 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
D-Hagz
Jul 4, 2015 02:19 AM
