P-650 rear brake stuck on!!
[img]i/expressions/face-icon-small-shocked.gif[/img]I have to put my quad in a heated garage every time I go riding?My rear brake sticks in the cold--any ideas??[img]i/expressions/face-icon-small-confused.gif[/img]
Banach,
When is the last time you changed the fluid in the rear diff? I'd also check and lube the cables. You may have water in the cables, boots, or in the diff itself. Make sure to use the Kawi fluid or Mobil 424 in the rear diff.
Peace,
Sgt_Rock
Peace,
Sgt_Rock
I've experienced the same thing as banach. I know my cables move freely. It it the lever that the cables hook on to that gerts jammed. You have to give it a few good shots to get it going. Anyone know if it would hurt to put some grease over that?
[img]i/expressions/face-icon-small-confused.gif[/img]I changed the rear fluid about 1 month ago---also lubed cables--found rubber boot loose near rear brake---hopefully that will do it--thanks for responses
SixSpeed5
8
Aug 2, 2015 05:38 PM
