P700 vibration
Old Jan 25, 2004 | 05:14 PM
STAKK's Avatar
Default P700 vibration
anyone had a vibration with their 700? I have noticed it the last two rides but have only rode four rides, It is worse in low range but almost as bad in high, I can feel it worse at about 10-15 mph, when I let off the gas it goes away, I can feel it through the whole bike and worse in the floorboards, the bike runs fine, just this vibration has me stumped, it almost feels like a bad cv joint or bearing from the factory, bike has 300 miles on it and started after the second ride about 200 miles, still has warranty but dealer is always swamped, if someone can help me not have to take to the dealer, I'd rather fix it myself unless it is a bearing or driveline problem.........
Old Jan 25, 2004 | 05:58 PM
mojavejack's Avatar
The engine balancer may be going bad?!?!?! that happened to my mojave
2002 mojave, 13 tooth front
k&n filter and dyno jet kit
dg chrome exhaust
Old Jan 25, 2004 | 06:21 PM
hammerman's Avatar
Does it do it in neutral when you rev the eng. Check your eng mounts and make sure there tight. If it does it only when riding put it in 2 wheel drive and jack up the rear to see if it is in the front or the rear.Jack up the front and shake the front wheels to see if there are any movement in the wheel bearings.Hope that helps.
Old Jan 25, 2004 | 09:56 PM
skun's Avatar
just a little tought my 600 grizzly had a vibration checked everything come to find out the belt had a bad spot on it but was not comming apart hope this helps
Old May 1, 2005 | 01:23 PM
650Freak's Avatar
STAKK: Did you figure it out yet. I've got the same problem with my prairie. I can feel the vibration right in the floor boards. I looked at the engine mounts and they look tight. I haven't put a wrench to them yet, but plan on it this week. I was also wondering if the rear u-joint might be going bad.
Dabears1983
Jun 23, 2015 04:59 AM
FireFighter
May 30, 2001 11:05 AM
ScoobyDFW
Apr 24, 2000 09:09 PM
Varso
Mar 14, 2000 09:46 AM
Hank
Nov 9, 1999 06:51 PM
