speed for mojave
Old Jan 25, 2004 | 05:51 PM
mojavejack's Avatar
Default speed for mojave
what is the stock top speed for a mojave and what is the best pipe for it? Any replys will help
Old Jan 25, 2004 | 05:53 PM
mojavejack's Avatar
I also have a 13 tooth front sproket
Old Jan 25, 2004 | 06:05 PM
mojavejack's Avatar
help?????????
Old Jan 25, 2004 | 06:34 PM
clover's Avatar
a stock mojave runs about 54mph and with an exhaust and 13t sprocket it will run about 57-60mph.
There is alot of good exhaust systems for the mojave my favorite is the white bros. or supertrap.
Old Jan 25, 2004 | 08:03 PM
rescuediver's Avatar
I'm very pleased with the supertrapp on my mojave.
Old Jan 25, 2004 | 08:28 PM
solid_fun's Avatar
My son just asked me what the Top speed for his Mojave should be we have clocked it at 100km really tight would say more likely around 97.(60.29 m/h) But after a few miles it start to skip and oil blows in the filter. The shop says it's the rev limiter kicking in.
Why after 1 year does this start? it's stock gear & piston. I did the engine mself.
If He pust a suppertrap on this will only add to his problem ,Correct.
Thanks
Old Feb 21, 2004 | 09:08 PM
BlasterBeater's Avatar
I discourage the DG Chromepower Exhaust (which I unfortunately paid $170.00 for). It makes much more power & torque than stock BUT there is no restriction so it's way too loud. Not just loud, one of the loudest ATV's on the trail; and it gets old very quickly!
Old Feb 22, 2004 | 09:05 AM
solid_fun, I am by no means a technical expert, But, I think the rev limiter kicks in because it's suppose to if your hitting the top end of the revs. It's keeps you from blowing up your engine.
There are quite a few guys on here that might be able to answer your questions if you post them separately? I really like my supertrapp, it's not to loud, In ca. you can't be over 96dbs and I know I'm not over that, it doesn't drive me crazy when I open it up and can no longer hear myself think. After I put the k&n on with the rejet, I was really impressed with the way it felt when I accelerated. Now, I like speed, but, I prefer to accelerating part better[img]i/expressions/face-icon-small-happy.gif[/img] JMO Dan
Old Feb 22, 2004 | 11:41 PM
juniorsmojave's Avatar
as for as the pipe goes the white bros pipe sounds awesome. it adds a alot to the bottom end with the filter and jet kit. if you have the 13t sprocket you will have everything. the only problem i have found is the pipe slightly rubs the tires when i bottom out. i have a 250r shock(not dialed in yet) and 20-11-10 holeshotes on douglas 190`s. if you tweak things around i am sure you could bypass the problem(not enough time yet).
Old Feb 23, 2004 | 12:06 AM
Chris142's Avatar
it's always had a rev limiter.....youv'e just never revved it high enough to hit it. As for the smoke. Theres a small clear tube that hangs below the airbox above the swingarm. It has a plug in it. Pull the plug to drain the box and reinstall the plug.
