Tire options on V Force?
Old Feb 6, 2004 | 08:25 PM
  #21
Cheezhead's Avatar
Default Tire options on V Force?
A stock V should be running in the 70-73 bracket Ive GPSd mine at 71 already several times.
Kevin
Old Feb 6, 2004 | 10:04 PM
  #22
Vforcer's Avatar
Originally posted by: msujon71
Vforcer,
What size tires are on a stock Prarie that you experimented with?
I was thinking of going from 22-11-10 to 24-11-10's... That is only about 1" farther out, and it looked like i should of plenty of room when i looked today at my V; but i'm not sure how much the tires would donut at high speeds as talked about.
Thanks
The stock P650 tires were 25" ... and kinda donut shaped. I decided to use Spider Tracs on my V, they are about 1" shorter tire than my stock V force tire. Then I put the Dalton overdrive clutch to hold the top speed where it was.... but I never run at the top speed. I just don't have a place here long and smooth enough to do that. The Spider Tracs are wonderful trail tires for the type of riding I do. ( I put them on 10" wide rims ... so they are wider than the stock tires ...)
Old Feb 7, 2004 | 02:47 AM
  #23
BigOne's Avatar
What trype off ground was this test done on? My V was gps at 71 on the road and only 60 on the side of a railraod bed, it was like crushed coal. It left roosts all the way down. My brothers kfx 400 did 63 in the same spot but cant beat me on the street.
The V needs more traction in alot off situations to get top speed out of it. I am 280 and my brother is 230 and we are both 6`5 + so my extra 50 lbs probally slowed me down on the soft trail.
Old Feb 7, 2004 | 03:11 AM
  #24
Cheezhead's Avatar
That 71 was on the road and Im 6 ' 1" and 260 lb
Kevin
Old Feb 7, 2004 | 03:51 AM
  #25
BigOne's Avatar
You ever notice that there is alot of big **** on the forum????
Everyone is huge and alot bigger than me, I guess I will have to change my name to kinda BigOne[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 16, 2004 | 04:02 PM
  #26
darthvader's Avatar
Hello fellow v force owners!I just put 25 " mud lites on my 04 v force.the top speed was slower but my hook up was better!I had to lean clear over the bars on 3\4" stone road in order tot keep the nose down.
I ate em up off the line but top speed was my problem--`````22`s are faster due to the clutch action-I think the tire mass kept the clutch from reaching full open.lookink at the nitrous kit for 770cash or the big bore kit785cc for 1100spacebucks!Also daulton industries has the clutch hook up for around 300bucks. I was beaten by a z 400[img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img]I`m gonna fix this #### right away! let me know what works and I`ll do the same.later--
--dv
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
ylomnstr
Sep 22, 2015 12:19 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
ylomnstr
Sep 4, 2015 05:02 PM
