V climbling hill = white smoke
I went to Winchester Bay Oregon for the first time this weekend. Great place to ride.
Anyway I was climbing Banshee hill which is really steep and long. At the top of the hill I looked back and noticed my exhaust was smoking. Once I leveled out it stoped.
I think maybe riding at that angle for the ~60 sec it takes to climb it may be rolling the oil back into the rear cylinder. What else could it be?
Has anyone else seen this?
Yep that's right .. if it was oil getting into the combustion chamber you'd be seeing blue smoke ..
Did you get a smell of the exhaust?? If coolant is getting into your combustion chamber, it will smell kinda sweet. Hopefully it's not a split head [img]i/expressions/face-icon-small-shocked.gif[/img] that wouldn't be good. Most likely a head gasket like Newbeatle said ...
Mine likes to do this too. I only notice it if I do a wheelie for a long distance. That puts the front end up at a similar angle to what you are talking about. It is a thick form of smoke and clears right up when I let it sit and run level for a few seconds... I was guessing it was coolant getting in there but from where??? [img]i/expressions/face-icon-small-confused.gif[/img]
I didn't think about it, but KEVINM is right, there is that little sediment bulb at the bottom of the Prairies filter box ( I assume there is one on the Force ), it is in front of the carbs on my quad, if there was moisture in there, a very steep hill could cause that to run out & be sucked into the carbs... It should only happen once though, if this happened repeatedly, it is unlikely that that would be the cause...
