I made aluminum radiator air scoops for the "V"...
Old Feb 28, 2004 | 11:27 PM
  #21
markkfx700's Avatar
Default I made aluminum radiator air scoops for the "V"...
thanks mark
Old Feb 28, 2004 | 11:37 PM
  #22
Mark82ndABN's Avatar
Mark, I meant to ask you before, what did you use to cut out the vents on your hood......yours came out great. I plan on cutting mine out sometime soon. Thanks.
Old Feb 28, 2004 | 11:43 PM
  #23
markkfx700's Avatar
i used a dremel tool and done it from the back side. Then took a fine file to remove all the bumps and where the plastic melted a very little bit. I also took a torch and ran over it fast front and back to melt any burrs off. Just take your time and it will come out nice. Mark
Old Feb 28, 2004 | 11:48 PM
  #24
Fantastic, thanks Mark.
Old Feb 28, 2004 | 11:54 PM
  #25
markkfx700's Avatar
Mark can you get a number to do the jet hot coating and did you teel them you wanted chrome or anything? thanks.
Old Feb 29, 2004 | 12:11 AM
  #26
Mark, here is their web site (phone number is in the upper left corner of their home page): www.jet-hot.com
The coating I had done is called their "Sterling" coat. They were awesome to deal with and had my pipes back to me in a weeks time. Only cost me $135 for both pipes.
Old Feb 29, 2004 | 03:20 AM
  #27
CRASHDOG's Avatar
hey mark,
i just sent you a e-mail for you to send me the info.
i have another question on the pipe thing.
if you coat the outside and that keeps the heat down on the outside does the heat get trapped on the inside and does that cause the motor to run hotter, i hope you understand my question.
thanks, crashdog
Old Feb 29, 2004 | 09:24 AM
  #28
higgsV's Avatar
heat goes out the hole, motor runs cooler. less heat around the outide of the motor as well, one of the mags took before and after jet-hot temps on the out side of the pipe. something like 500 degrees without 250 degrees with coating. my two pennies for you.
Old Feb 29, 2004 | 09:25 AM
  #29
higgsV's Avatar
hey markskfx.......how much of a difference-powerwise did the 20inch tires make?
Old Feb 29, 2004 | 03:49 PM
  #30
venforcer's Avatar
Check out my radiator guard. It installs right under the cheezey stock one. I have'nt found a an aftermarket one anywhere. easy to make. just flat .125 aluminum plate.[img]i/expressions/face-icon-small-smile.gif[/img]
