NITROUS on their V?
Old Feb 25, 2004 | 02:43 AM
zmann's Avatar
Default NITROUS on their V?
ok, let me check tommorrow. I think it would be best to mount a activation button by one of the grips for you to push to turn the spray "on". Other than that, should be very cool.
Old Feb 25, 2004 | 02:44 AM
markkfx700's Avatar
thanks will have to get back to you on friday i fly to reno again tomorrow thanks again.
Old Feb 25, 2004 | 08:23 AM
RocketJoe's Avatar
Here is a helpful site on building your own system and even if you’re not going to build your own this is a very informative site on Nitrous.
http://www.diy-nitrous.fsnet.co.uk/
RJ
Old Feb 25, 2004 | 09:22 AM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
I do a lot of NOS and NX installs on DS's. On the V, would you put the nozzles in the rubber intake? I have seen this done on a DS with duel carbs that had a rubber intake. The intake was drilled and the nozzles were screwed in and still seem loose. With a little silicone and a couple of zip ties, it just made sure they didn't pull out.
I have seen one V with NX on it were I ride, but I didn't get a chance to look at the install.
Old Feb 25, 2004 | 11:26 AM
  #15
zmann's Avatar
Yeah, That is what I would do. Plus, the NX stuff has a sort of lock washer thing that you tighten up on the intake boot and then screw the shark nozzle into that.
Old Feb 25, 2004 | 11:39 AM
  #16
TEDDY700's Avatar
i just recieved my kit the other day and will post when i get it installed. i went with the boondockers kit. seemed simple and cut n dry. and alot safe r than other systems. will post soon
Old Feb 25, 2004 | 12:30 PM
  #17
blasterrcr9587's Avatar
i heard that with the nos system u could hook it up so when you hit the button, it gets sprayed right onto the airfilter. would this be a good setup or would it be a waste?
Old Feb 25, 2004 | 02:04 PM
  #18
zmann's Avatar
I assuem the NOS kit is a dry kit? See, that gets into the whole dry vs. wet kit debate. I personally like to know that my fuel is going in with the nitrous.
Old Feb 25, 2004 | 02:10 PM
  #19
TechTip101's Avatar
if you go to the boondocker site there is a V-force with the kit on it. Actually 2.
Old Feb 25, 2004 | 07:52 PM
  #20
DesertSportsman's Avatar
Just adding myself to the thread for updates for TEddy700. I too think the Boondocker system is fail-safe if installed correctly and 15-20% in hp is very respectable.
