Got my 700 stuck, in my front yard :)
Old Mar 25, 2004 | 06:40 PM
bbertram's Avatar
Default Got my 700 stuck, in my front yard :)
Don't let your dad do that ever again and do not do it yourself. The front tires should be moving when your engaging the 4x4 or else you may bust the actuator that engages the front end. I don't like the 4x4 system myself, well the way its engaged. You should have the quad rolling around atleast 3-5 mph when changing from 2x4 to 4x4. This makes things safe and you won't bust anything.
Old Mar 25, 2004 | 06:50 PM
maddog56's Avatar
well that sucks. I guess if I get stuck in a hole in 2wd im screwed huh. What a gip.
Old Mar 25, 2004 | 06:51 PM
Kawi650's Avatar
Originally posted by: tech52
sound's like you should have bought a bike with independant rear suspension!! just kidding. I'll still go riding with you and pull you out when you get stuck, that's what friends are for, right.
no...this is where a tow rope and a set of tracks come in[img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 26, 2004 | 09:52 AM
bbertram's Avatar
Yes it does suck, so don't go playing in an unknown mud hole while in 2wd. This is one of the few drawbacks about the Praire, the other is big tires and the diff lock. When you put on big heavy tires the diff lock needs to be tightned up to a degree where it is almost always on with no pressure on the lever. But that extra pressure is required because the front diff uses clutches and friction to lock up so the heavy tires require more clutch pressure and thus the need to tighten the diff cable up. When you do this you get your diff semi locked all the time which can be a good thing I suppose but I see in the future my diff lock not working in a couple of years with my big tires as the clutches will need replacing.
When I mention big tires, I mean heavy tires like Vamps, outlaws and mudzillas. These are heavy tires, mud lites, dirt devils, mud bugs, etc are not heavy tires.
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
micheleLeigh
Jul 19, 2015 07:32 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tporath
Jul 11, 2015 12:31 PM
