PINK SPRINGS AND SHIMS???
Old Mar 25, 2004 | 06:42 PM
DRDANTDC's Avatar
Default PINK SPRINGS AND SHIMS???
[img]i/expressions/face-icon-small-confused.gif[/img] I HAVE A 2004 VFORCE, I JUST ORDERED A PINK SPRING FOR EPI. I HAVE BEEN READING ABOUT USING PINK SPRING WITH 2 SHIMS. I HAVE A FEW QUESTIONS. WHAT ARE THE SHIMS SUPPOSED TO DO, WHERE DO THEY FIT IN RELATION TO THE PRIMARY SPRING, AND WHERE CAN I PURCHASE A SHIM. ANY HELP WOULD BE MUCH APPRECIATED.
Old Mar 25, 2004 | 08:52 PM
MentalState's Avatar
With the pink spring you have very little or no stall..By placing shims(washers) between the clutch and spring you create more of a stall...
Old Mar 25, 2004 | 09:17 PM
DRDANTDC's Avatar
IS IT A HUGE DIFFERENCE IN THE STALL, AND WHERE CAN I BUY THE SHIMS.
Old Mar 25, 2004 | 09:36 PM
Not sure where to get shims...probably same people you got spring from...Try and PM a member named kevinM he has alot of the answers you are lookin for..But as far as shims go the more you add the higher the stall....
Old Mar 25, 2004 | 10:09 PM
beetlegus's Avatar
I got the pink spring. It's worth the money, if it is your first upgrade. You can definetly feel it pull harder to the top speed. And as far as the shims go I ordered 2 of them, but the damn dealer put them on backorder. It's been 2 weeks since I ordered them, I'm starting to get a little bit pissed. Anyways, you will need to get the shims either from a Kawasaki Dealer or a Polaris dealer, as the shims are interchangeable. So if one dealer doesn't have it maybe the other will. Here are the part numbers you will need. Kawasaki part # 92026-1603 and Polaris part #7555899. Good luck with this.
Old Mar 25, 2004 | 11:11 PM
venforcer's Avatar
Dont add more than 3 shims as it could cause the coils of the spring to bottom out and bind the spring. I put three shims in and the stall is perfect. The shims also increase the shiftout, whitch increases top speed.
Old Mar 26, 2004 | 12:00 AM
vtwiner's Avatar
I'm not sure why someone would go to the dealer for shims. They are only large washers. The V comes stock with 1 shim under the primary spring. Just remove the stock shim and take it to your local hardware store and match it up. Simple as that!
Old Mar 26, 2004 | 12:12 AM
venforcer's Avatar
THE STOCK SHIM IS 1.2 mm THICK. I MADE A SHIM FROM A WASHER THAT WAS 2.5 mm. THAT IS .1 mm MORE THAN THREE STOCK SHIMS. STALL AND SHIFTOUT IS PERFECT FOR MY STYLE.
Old Mar 26, 2004 | 10:18 AM
newbeatle's Avatar
On the Prairies, it was reported that each ( stock thickness )shim adds roughly 100 rpm to the stall... I would think it would be very similar for the V's...
Old Mar 26, 2004 | 01:25 PM
DRDANTDC's Avatar
THANKS FOR THE INFORMATION, THIS SHOULD BE VERY HELPFUL.
