New CDI, mods, and tests
2p700s that screw size is 4mm-14mm. you can find stainless steel screws. they use the 3mm allen wrench.
_________________
02 650p
nyroc muffler
napa #7335
145f/147.5r jets
epi black
700p drive spring
warn 2000
plow
_________________
02 650p
nyroc muffler
napa #7335
145f/147.5r jets
epi black
700p drive spring
warn 2000
plow
No problem, newbeatle. I got the info from another forum/posting, too. At least I was able to use it by incorporating the stock water trap, in a way it worked out for the best. I still have the water trap (which is of a large diameter anyway) and was able to get rid of the restrictive snorkle section.
#15
2Prairies, as for jetting I'm wondering if you'll be changing filters or not along with the snorkel mod. I run the NAPA hose with a K&N filter, needles shimmed at .040 and at 142 & 145 I'm just a touch lean on top end. This would only be a guess on my part, but when the CDI shows up I'm going to jet to 145 & 148 to start and see what happens. BTW I'm at 835' msl. and altitude makes a difference.
I too would like to hear a stock for stock comp with the CDI.
kbazzy
Sep 26, 2015 11:26 AM
Sep 23, 2015 06:23 AM
