moron question (need help ASAP)
There is some stuff they use when you have a tire that constantly leaks around the bead looks like tar but a better solution in that case is a tube. The other stuff is a pain to clean off the rim and I don't think it works all that well.
The stuff you are looking for is actually called bead sealer, black stuff comes in a can with a brush. when it does fully dry you can peel it off fairly easy. Most parts stores dont carry it but most tire shops do. hope this helps.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
slowgsxr97
Sep 8, 2015 07:33 PM
