MOJAVE jet kit, SUPERTRAPP, cool air intake, HELP ME OUT
I need to learn how to replace a inlet and exaust sprocket willing to pay someone if they are in PA and wanna do it. I bought it all messed upa nd i just want someone to tell me how to fix it or fix it for me. i have tons of mods on this thing i just dont think i am going to be able to go it to be exactly centered or if there is a trick for it. COME ON I KNOW SOMEONE KNOWS HOW?
what youll need to do is pull off all the plastics and the gas tank to get to your vlale cover there should be 6 bolts take them out if the engine i already in time then remember exactly where the marks on the gears are then pull the main caps off there 2 bolts apice there are 4 main caps tip the cam to get the timeing chain off if u have a table clamp it will make this part a lot easier wrap the end of your cam shafte in a town not to scratch the surface of the cam tighten it down prety tight and remove the bolt that holds the gear on do the same on the next cam and put them back the posite way u took them out hope that will help u and if u have ne cams in good condition ide like to take a look at em
Scooter's Shop
23
10-22-2015 07:04 PM
IMLN
09-28-2015 03:32 PM
Quadzilla Heritage
09-25-2015 01:39 PM
