cams-cams cams
Old Apr 15, 2004 | 10:59 PM
lawnboy's Avatar
Default cams-cams cams
I have a couple questions about cams i would greatly welcome any advise or input ,when retarding your cams 10* how many teeth skipped (left or right) is needed, will the 700 v-force stock cams be any benifit to the prarie, also what is the best aftermarket cams for the prarie. RIDE ON
Old Apr 16, 2004 | 03:13 AM
huskerjim's Avatar
one only will affect the timing much anymore you will have a problem starting the beast.
Old Apr 16, 2004 | 09:10 AM
SHOTGUN's Avatar
1. one tooth on the intermediate shaft
2. V-force cams will work...
3. Talk to Mickey Dunlap after 3pm on the wildest cams. 814-842-6159
Come up this summer and pull.
Old Apr 16, 2004 | 09:19 AM
lawnboy's Avatar
thanks for the info very helpful, so the stock v-force cams already are 10*retarded. Probably a stupid question , but what is the intermadiate side. I think i met you before shotgun at a pull but you had the green penland plastic. Just let me know when the events are and ill be there. thanks ride on
Old Apr 16, 2004 | 09:31 AM
SHOTGUN's Avatar
I'll have 1-2 pulls in June, 2-3 in July and 3-4 in August.
Nope that wasn't me with the Penland Green, that was Adam Powers, runs tires like mine, only they are Cepec's.
Do a search, try Red650 or Novakaw650, they have had the 10 degree cam change, I think they have explained it a few times. Red650, aka Dale Brooks, I think was the first to do it.
Good luck. Hope to see you this summer.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
QuadRiders
Oct 22, 2015 04:13 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Canamaniac!
Sep 15, 2015 06:19 PM
