Proper 4 stroke plug coloration
Old Apr 25, 2004 | 02:18 PM
bbertram's Avatar
Default Proper 4 stroke plug coloration
Actually, its funny you mentioned the moon. Last night I built this jump, I hit it a tad to fast and well...ummm...your not going to believe this. I jumped so high I hit the moon. I know I know, you don't believe me but next time you see Santa Clause ask him about it. Thats where he hides in the summer.
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 25, 2004 | 03:22 PM
Lightman's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img] Take some pics next time, that must be some jump =]
Old Apr 25, 2004 | 08:37 PM
Chris142's Avatar
Plug color wont tell you much unless your jetting is way off.
Todays gas has no lead and burns very clean. The best way to jet a bike/atv is with a dino that shows the fuel curve vs rpm and load..
Old Apr 25, 2004 | 08:54 PM
springdrl's Avatar
More brown than white IMO. A mixture that is too lean (white coloration) can burn valves, whereas the only negative from a more rich mixture is shorter plug life. And since plugs are a lot cheaper and easier to replace than valves, the decision is an easy one.
Old Apr 25, 2004 | 08:57 PM
  #15
Chris142's Avatar
Wrong. An extreemly rich mixture will remove the thin film of oil from the cylinder. Once this happens the rings wear out in a matter of hours.
Old Apr 25, 2004 | 11:33 PM
  #16
Lightman's Avatar
Guys, 4stroke plugs are NOT supposed to be brown, or any shade of it. You are stuck in 2 stroke mentality. Lubrication is separate from fuel air mixture, and therefore your only enemy is too much heat/detonation/preignition, which is evident by a totally white plug, or other signs on the plug. Just a shade darker than white guys.... [img]i/expressions/face-icon-small-wink.gif[/img]
Chris 142, I disagree on the best way to tune/jet an engine as being on a dyno. I would much prefer for fine tuning an EGT gauge to dial in the exact combustion temps that were ideal, as well as a real time digital tach. Dynos are less accurate than real use, with a real load, and 50+mph winds blowing in the intake etc. I dont think any fan at a dyno facility can really replicate real riding.
In any case, with 4strokes, jetting/mixtures IS NOT nearly as crucial as in a 2stroke. Get it so that it runs well with no hesitations and good power, and a dark white/light light tan and you're good =]
Big bousse
Sep 26, 2015 10:42 AM
Schneider
Jul 24, 2015 05:05 PM
Captjay
Jul 23, 2015 12:33 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
