dayco belt book
got a new dayco belt book today # 047060 ,dayco snowmobile & outdoor activity belt catalog.
tried scanning it but that didnt work so here is the info.
year model engine oem # dayco top width outside cercumference in inches
2004 kfx 700 v force 697 cc 59011-0003 hp2017 1.125 33.375
2004 kfx 700 v force 697cc 59011-000 hp2017 1.125 33.375
2004 prairie 700 697cc 59011-0003 hp2017 1.125 33.375
2004 prairie 700 697cc 59011-000 hp2017 1.125 33.375
2003 prairie 650 633cc 59011-108 hp2018 1.125 33.563
2003 prairie 650 633cc 59011-1080 hp2018 1.125 33.563
2002 prairie 650 633cc 59011-1080 hp2018 1.125 33.563
2002 prairie 650 633cc 59011-108 hp2018 1.125 33.563
it appears that this line of belts do not have the vented "top cog" i have ordered a hp2018 but have not received it yet. will confirm when i get it.
I know the width but not the diameter/length. I may experiement with a P360 belt before the Summer is over.
I got a new belt by Dayco for my 650 about a week ago.
It does not have the top cogs. I do not think it will heat up the clutch or belt. The cvt system has a built in "blower" on the primary to create a positive pressure in the case.(cools and keeps out water,dust)
It looks like a good quality belt.(seen many, I'm a millwright)It's a couple of thousands wider than stock.
I only found out about the 700 belt after I ordered the 650.
However the HP2018 is still wider than the OEM belt.
I changed the belt. The original was glazed and getting a little hard. My fault, I tortured it by towing extremely heavy, snow plowing and I got it wet once with out giving it time to dry off.
P.S., it only has 1100kms.
The dayco belt was the exact same length as the OEM, but a bit wider. (30 to 40 thou)My digital vernier calipers battery starting to die, can't get an exact reading.
I reshimed it, and installed the belt. Man, I needed a new belt! I now remember why I bought this thing. It grabs much quicker than my tired belt, but "SEEMS" to be better than when it was new.
I will test top speed another day and let you know what the results are.
Oh by the way, the best place to buy a belt would be at an Industrial Supplier such as
Acklands Grainger.
In the past, I have found this type of supplier tends to charge less for belts and hoses.
I tried to search the belt on their online catalog, but I could not find it. However I was told that they do carry Dayco belts and can order it.
Acklands Grainger.
