P 360 holeshot module
Old May 13, 2004 | 03:48 PM
  #21
MikeRhyne's Avatar
Default P 360 holeshot module
Well 40 is as fast as we got it - we may have been able to squeze a few more out of it just didn't have a whole lot of space. We were at 8,000 to 10,000 feet over the weekend. The carb is jetting for alltitude already and runs pretty well not sure which jet as the dealer did it.
Thanks
Old May 13, 2004 | 07:23 PM
  #22
Uinthas's Avatar
oldman, I forgot the book [img]i/expressions/face-icon-small-shocked.gif[/img] sorry,(hooking the boat up for some fishing tonight & forgot) I'll get it tomarow & make copy's & fax them over
Old May 14, 2004 | 11:37 AM
  #23
Uinthas's Avatar
Oldman, I faxed over the wiring diagram (2 pages).. Hope you understand it better then I..
Old May 14, 2004 | 12:35 PM
  #24
OleManMoses's Avatar
Thanks ole buddy---but I need you to verify a couple of things--FAX's SUCK!!!
I cant make out a color(the most important one) and maybe you can verify for me
On page two--middle right side you will see "speed sensor"
Three wires coming off of it
Bottom wire is BK/Y and goes to ground on Battery
Middle wire is BR and goes to Actuator
Top wire (the important one) is G (I think, please verify) and goes to first junction and heads north toward the actuator--track this wire--does it turn into a P where it enters actuator???
If it does, then this would be the right wire. I will try cutting this weekend and see if any performance loss (or gain) is noted.
Let me know.
Old May 14, 2004 | 12:49 PM
  #25
newbeatle's Avatar
It should'nt matter the color of the wire, but it looks like you are on the right track, if that turns out to be the right speed sensor wire, P.M. me an addy, If you still want to try this... beware, it could damage either the CDI, or the module... I'm willing to risk the Nabor module, if you decide to risk your CDI... Let me know
Old May 14, 2004 | 04:50 PM
  #26
Uinthas's Avatar
Let me know.
Correct, from the top of the speed sensor it is "G" wich connects with the "p" wire to the actulator controller..
Old May 25, 2004 | 05:39 PM
  #27
Kartmann's Avatar
Has there been a conclusion? Will the holeshot module work?
Old May 25, 2004 | 05:48 PM
  #28
newbeatle's Avatar
MOSES did disconect his speed sensor, & it did act similarly to the "big" prairie... after I get a few mud races out of the way, I'll go to the drag strip one more time with the modules, then I'll send him one to try... sorry for the delay, but I really want to get hard & fast data on the modules, before giving one up...
Old May 25, 2004 | 05:56 PM
  #29
Kartmann's Avatar
I appreciate your and Oldman's help
MikeyBoyesq
Nov 27, 2020 02:44 PM
STLyamwar
Jul 25, 2020 04:44 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
ltrmc02
Jul 22, 2015 04:50 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
