2 stroke spark plug question
Old May 14, 2004 | 07:45 PM
warmdye's Avatar
Default 2 stroke spark plug question
I recently bought an 87 tecate 4 and it keeps burning up stator coils. The plug I am running and what came in the bike when I bought it used is NGK BR8ES. I noticed today in my manual it calls for a B8ES. I called the auto parts store and they said it was the same plug but a different heat range. Could this be what is burning up my coil? Does anybody know any reason why the previous owner would run a BR8ES? Any input is appreciated.
Old May 14, 2004 | 08:26 PM
Lightman's Avatar
There is no difference in those two plugs. The R denotes a resistor type plug, which is required for vehicles with electric gauges etc. 8 is the heat range.
Old May 14, 2004 | 10:10 PM
morehorsepower's Avatar
BIO is right same heat range
Old May 14, 2004 | 10:22 PM
Tecate4Fun's Avatar
I run B8ES and have great luck with them. Also run Klotz Techniplate with no fouling issues.
Old May 14, 2004 | 10:25 PM
warmdye's Avatar
So Tecate4fun, have you ever had any stator issues? If so I could use some help. I can't seem to get a stator coil to last more than 3 hours. I have a good email detailing the whole issue if you would like to see it.
I see you now have an aftermarket igition. how does that treat you? Can you run a light with that? Why did you switch from stock?
Old May 14, 2004 | 10:37 PM
warmdye's Avatar
I've looked everywhere, i can't find the motoplate ignition you speak of. where did you find it?
Old May 14, 2004 | 10:38 PM
warmdye's Avatar
so do you think I should stop using the BR8ES? I have about five of them laying around. sorry for all the post, I forgot about the edit feature.
Old May 14, 2004 | 10:54 PM
Tecate4Fun's Avatar
The Motoplat ignition is a racing iginition. I can not run the light. I would highly recommend some type of racing ignition. The performance improvement is truely amazing.
Old May 14, 2004 | 11:06 PM
Lightman's Avatar
br8es will perform identically to b8es.
Old May 15, 2004 | 01:29 AM
warmdye's Avatar
So where did you purchase your ignition?
kelleycully
Sep 15, 2016 02:57 AM
Ramman1
Jun 16, 2016 09:07 PM
200es
Jul 10, 2015 09:09 AM
D-Hagz
Jul 4, 2015 02:19 AM
Shifts
Jul 3, 2015 07:59 AM
