stripped oil plug
Old May 17, 2004 | 11:56 PM
mojaveaddict's Avatar
Default stripped oil plug
nutserts are great but you will prevent the last amount of oil and trash from draining like Nyroc said. I have used them on stripped mojave cases but had the case split and could grind one side of the nutsert down to case level to allow draining. If you do not want to split the case get a 12 mm oversize plug from the auto parts store. I bought a self tapping oversize 12mm plug from PEP Boys and it worked great on a mojave case that was stripped. It has course threads where the stock plug has a fine thread. Fine threads and aluminum do not mix.
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Captjay
Jul 23, 2015 12:33 PM
