mojave oil change need help quick
Old May 27, 2004 | 10:29 PM
MojaveCA's Avatar
Default mojave oil change need help quick
i was changing the oil and filter for the first time and after i let the oil drain i tried to get the oil filter cover off by removing the two screws but its still hard to get off. I was wondering if i was supposed to remove something else or if anyone has a simple trick to help me out. Any help is appreciated.
Old May 27, 2004 | 10:36 PM
Kawibayou185's Avatar
Hello,
It may just be stuck by the gasket, or gook and grime???
Old May 27, 2004 | 10:48 PM
MojaveCA's Avatar
okay cause then ill use a little force to pull if off i was afraid i might have forgotten to unscrew somthing am i suppose to twist it off or should it just pop off?
Old May 27, 2004 | 11:11 PM
MojaveCA's Avatar
nevermind i got it off but now i have another problem i cant find the pin, i took the cover off and i looked for a pin and i didnt see one so i pull on the filter and it came out with the grommet in the middle then i looked at both sides and there was pin and i pushed on the grommet and it slid off the filter, now i dont know where the pin is, or if their even was one since i bought this atv used. Any one know where it might be and if its important or can i just put the new filter in?
Old May 27, 2004 | 11:38 PM
MojaveCA's Avatar
okay i think i figure it out. Grommets are the black things on the openings of the filter, and the pin is the cylinderical thing in the middle, right?
Old May 28, 2004 | 01:16 AM
Chris142's Avatar
Yup. Actully the pin is the bypass valve. It will only go in the engine one way.
cornermike
Sep 10, 2015 08:30 AM
Albertaboyy
Sep 9, 2015 09:51 AM
Rooky
Sep 9, 2015 03:16 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Elkaholic
Sep 6, 2015 02:44 PM
