6 degree key / timing key
Old Jun 13, 2004 | 05:40 PM
Spaz40's Avatar
Default 6 degree key / timing key
Where can I get a 6 degree key? Has any one sloted there timing plate, and if so how did it turn out. This would be the formula to do so. Timing plate bolt pattern X pi (3.14159)= circumfrance 6 degrees devided by 360 degrees=.01666 Now multiply circumfrance by .01666= the amount you would rotate your timing plate on the bolt pattern circumfrance. I have not had mine apart but I asume the timing plate is bolted on. I may try this myself if I can get some free time.
Old Jun 13, 2004 | 08:09 PM
Spaz40's Avatar
Just got mine apart, dont think moving the pickup will work. You would have to move it 5/16" and it is not on a plate, not really posible and be worry free. Still looking for a key that is offset not ground.
Old Jun 14, 2004 | 01:00 AM
Pistonman's Avatar
Check out Venforcer on this forum, he has them.
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
ghost civic
Jul 19, 2015 10:13 AM
95wolv
Jul 17, 2015 08:13 PM
