650 SUSPENSION
Old Jun 22, 2004 | 05:40 PM
mainman's Avatar
Default 650 SUSPENSION
HI ALL , I HAVE A 650 PEARIE 02 , THE REAR SUSPENSION IS NOT SITTING QUITE AS HIGH AS THE FRONT , IF YOU ASIST AT THE REAR RACK IT RISES 2-3 INCH . CAN YOU CHARGE SYSTEM OR IS IT A SPECIALIST JOB , THANKS IN ADVANCE .
Old Jun 22, 2004 | 06:46 PM
reds650's Avatar
If you want it stiffer in the rear turn the nut down on the shock it puts preload on the spring
The charge is to keep the oil in the shock from foaming not giving more ride hight
Old Jun 22, 2004 | 09:18 PM
sledheadrich's Avatar
The "sag" or "ride in " as it's sometimes called is a desireable condition of a broken in suspension. It allows the suspension to 'fall" into holes which transfers less shock to the rider. As long as you're not bottoming out too easily you have nothing to worry about.
Old Jun 22, 2004 | 09:22 PM
NovaKaw650's Avatar
What reds650 said. A typical race bike set up is to have 1/3 of the suspension travel at the top when at rest.
Old Jun 23, 2004 | 01:51 AM
MikeyBoyesq's Avatar
Speaking of P650 Suspension, has anyone ever heard of installing anti-sway bars on the front of an ATV to help it handle better in turns. Is this possible and if so, can it be done to the P650/P700???
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Nekolai1
Aug 25, 2015 10:04 PM
Mssarabug
Aug 10, 2015 12:56 PM
