Who has temp guages
Old Jun 24, 2004 | 09:24 PM
mikee2's Avatar
Default Who has temp guages
I want to get a temp guage for my 700. Where is the best place to get them and what is everyone running. Mechanical or 12 volt. I have always liked mechanical better myself but 12 volt may be just as good. Do you have to buy one for a atv or will a autometer work.
Old Jun 24, 2004 | 10:23 PM
kawakasi's Avatar
I got a el-cheep-o on my 02
Mechanical...bought it @ my local auto parts store
Had to buy some fittings too
Best 19 bucks I ever spent
Old Jun 24, 2004 | 11:22 PM
wildrides's Avatar
kawakasi
where did you tap in the line and mount the guage? Look cool, run cool?
Old Jun 24, 2004 | 11:25 PM
LuvDaMud's Avatar
I bought a 12v for under 20 Bucks at my local parts store. I like it cause it has a light inside so I see it well at night. The fan only kicks in at about 205 Deg.F. so I put a manual switch in parallel with the temp. activated fan switch of the bike. I usually put the fan on when I take off, It tends to hover around 180 Deg. , I find that more comferting than 205 - 220 Deg . When I get in deep water or mud I flip off the fan switch . If I forget to flip it back on , it will still go on automatically at 205.
I strongly suggest it since the V-Twin engine head gaskets are very susceptible to overheating. I learned it the hard way!!
_________________________
2003 P650 Red
Holeshot Module
Dalton Springs
ITP C-Series Rims
26in Bear Claws
Full 2 peice skid plate
Kimpex Snow Trax for deep snow
Full Equiped
Old Jun 24, 2004 | 11:30 PM
wildrides's Avatar
luv da mud
what happened to the gaskets? What did you have to do to fix? warped heads? How did you know?
I overheated mine and it eats a little coolant and sounds like the valves are loud now.
Old Jun 24, 2004 | 11:43 PM
LuvDaMud's Avatar
It started to blow coolant back in the rad. reserve tank, and out the overflow. The compresion was blowing air in the coolant through the breach in the rear piston. Luckilly I found out soon enough that they only had to replace the gasket . The way to check for a breach is to remove a spark plug and put air pressure in the hole(aprox. 40 PSI). while the rad. cap is off. If there is a gasket breach you will see the coolant level rise and might even see bubbles come out .
Do the same for each piston.
Old Jun 25, 2004 | 12:00 AM
LuvDaMud's Avatar
Just check out my pics. in the gallery. It might explain why I suggest installing a temp. guage. I like to find its' limitations. I now know it loves mud and water plenty . Thats why I made a Nice set of stainless teeth for my BEAST!. And lets be honest ; I didn't buy the thing to go to Mass on Sundays LOL.
Old Jun 25, 2004 | 12:08 AM
wildrides's Avatar
can't wait to burn up my tires, the stockers are about toast with 50 hours on it.
Old Jun 25, 2004 | 07:54 AM
LuvDaMud's Avatar
I had aprox. 4000 miles on those Bear Claws when I decided to burn em. I have close to 5000 miles on my P650 ,2003 so far . By now I know all the trails in my county like the back of my hand.
Old Jun 25, 2004 | 10:37 AM
VNASTY's Avatar
I got this one- http://cgi.ebay.com/ebaymotors/ws/eB...tem=2482309407
